Cannot log in, https://arlo.netgear.com/#/login on my iMac just loads a blank page. FRUSTRATING !
Just FYI --- You should not have to uninstall and reinstall the Arlo app to get things working when the issue is a system outage on the Arlo side. Logging out and back in might help once the service is restored, but uninstall and reinstall is not needed.
In fact, there is currently a bug in the andriod app (just sure about iOS) where if you uninstall and reinstall you will now get double notification sounds from the Arloo app. Uninstall and reinstall again to try and fix that and you get triple sounds, and so on and so on. There are multiple posts in this forum that cover the uninstall reinstall multiple notification sounds isses.
@Dave7mack wrote:
This is a new purchase and I hope this is a very exceptional situation. .
Unfortunately 2018 has not been a good year for Arlo. Beginning of the year the Arlo database went down. After that user accounts were corrupted and once database was restored many people were offline. Some for weeks, up to a month. Some people manage to get their system back others it came back eventually on it's own. Then after that came the battery drain issue where the IR lights on the camera came on after the cameras were turned off. Took a month for that fix, but that brought other battery issues, motion issue, cameras offline issues. Then another firmware update, which fix things for most, but not for many others. Then another firmware update that broke working people, fixed some, made others worse. After several firware updates, many still report the same problems. Now the service goes down again.
There are just 5 examples of major problems in 2018, plus all the little bugs in the apps and firware as well.
Hopefully it's just growing pains as we are technically earliy adopters of such technology in the home. Either things get better or we all start switching to another product.
Yeah, I made that mistake of uninstalling/re-installing the app and had up to 4 notification sounds. Fixed it by uninstalling the app, running CCleaner on my smartphone and re-installing app. Back to one notification sound.
Ccleaner........ good call. Even though I have an android phone I'm not an android person so I had no idea ccleaner had an android app. I've used it for years on windows computers. There was a manual fix posted, and I've been too busy to do it to fix my double notification issue, so I haven't done it yet. I'm going to try your method.
See post number 111 in this thread:
https://community.netgear.com/t5/Arlo-Pro/Is-ARLO-Down-AGAIN/td-p/1618055/page/5
USA , Oklahoma, android phone!
ive gotten zero alerts or notifications since it "came back up"...ive even tried walking in front of all of my cameras...and nothing.
all cameras test fine using the "live preview" mode.
super awesome product arlo!
Issue still exists with my Main Account, can't access and keeps getting
"We are sorry. The system is experiencing an unexpected issue" upon login try
If anyone that still cannot login would be willing to get on a call with engineering, please PM me.
@KathyTW I just sent you a PM. You can check your message by clicking on the envelope icon in the upper right corner next to your username.
When is this getting fix
