Lots of times recently when I try to view my camera activity on my phone I have been getting the message, "You are not connected to the Internet. Please check your connection." There is nothing wrong with my connection. Everything but Arlo is connected. What's wrong?
I am having the same problem. I will try uninstalling the app and reinstalling. The cameras generally show online in the website when they appear offline in the app.
The app update seemed to have fixed this for me. Had to login again and it was lightning fast to load the feed on the "unit" page in the app. I did get one "you have been loged out because of another login from another device" warning at one time but it went away in less than a second. Just a bugged warning at the top.
Does this issue still occur with the latest version of the Arlo Mobile App 2.20?
@CP312
I think you might have another type of issue/problem since you describe it as constantly offline. The bug was that it had offline status for up to 60sec before it worked. Have you tried unplugging and replugging the basestation or camera if its wifi cameras? And log out and back in to the app?
Resolved issue I was seeing across multiple apple devices. Much better...Thank you.
APP 2.20(1201) Released 9/5/2020 seems to have resolved this issue
JimK; Humanity over Flag
Hello,
This issue should now be resolved. Please make sure you have the latest version of the Arlo Mobile App v2.20.
Hi
Not had any re-occurrence since the update.
Josh
I have not had issue since update, all 3 iOS devices working as expected.
