Lots of times recently when I try to view my camera activity on my phone I have been getting the message, "You are not connected to the Internet. Please check your connection." There is nothing wrong with my connection. Everything but Arlo is connected. What's wrong?
I’ve had the same issues since purchasing about a month ago. I was instructed to update app to version 2.19.2. When I went to App Store it didn’t show any updates so I deleted and reinstalled app which then showed the new version. Since I updated my system works 99% of the time.
Have you tried unplugging base station so it resets itself, sometimes that will work. The only other thing I could think of is to do a factory reset by using a pin to press the reset button on back of base station. This will revert to factory settings, then you will have to reinstall everything and resync the cameras. Good luck.
Ps. I’m convinced it’s a software issue as it’s in been happing for the last week or so and I still get notifications of motion and video in my library even though I can’t live view and it says offline!
I agree it’s a software issue. Their costumer support Is not very good, they take forever to reply and don’t acknowledge that there is a problem.
I have downloaded the version 2.19.2 app (iPhone SE 2020 version) and it seems to have fixed the intermittent "offline" problem. Will give it some more time and report if there are any further issues.
Cheers.
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Is it intermittently offline, or permanently offline?
Did you perform a factory reset? It appears you reset it then able to onboard the base back to your account but it appears offline? Is that correct?
Camera works in HomeKit
Yes, this is a factory reset & you will need to install the base & cameras once again.
If it successfully reset, you will need to onboard through the app or web portal again.
So, following my last post the cameras stayed online for approximately 24hrs and are now offline again. It has to be a software issue as I still get notifications for motion and the library is storing clips.
I'll update my case with the tech team and report any feedback.
ps. it seems I've got the most up to date app but I'll delete it and reinstall for the sake of it.
I have updated my iPhone arlo app, and the camreas are offline.
My ipad with the old version of arlo app the cameras are online and no problem.
Go to:
* Settings
* * Profile
* * * Login Settings
* * * * Two-Step Verification
Update, and the carmaras are back online.
I have ARLO VMB4000r3. App is telling me my base station and cameras are offline. Then finally after 5 minutes or so of waiting they suddenly appear to be connected. I thought maybe was router issues, but now think its Arlo. Also camera notifications are not syncing: after viewing a recording, the app still shows it as new. Latest update was wonked out IMO
Ive had intermittent offline issues with my Arlo pros and my Arlo Qs. Motion detection Notifications and recording still work But the app shows the cameras offline. The cameras will still load through Apple home kit. Sometimes cycling through the different tabs in the app will allow the cameras to come back “online”.
Arlo support stopped responding to my support ticket so I don’t have any solutions yet.
