Re: GEOFENCING IS BROKEN. ANY FIX NETGEAR?!
- Email to a Friend
Hi,
2 days ago there was a bug fix update version 2.79 since then the geofencing doesn’t work properly,, when I leave my premises it works fine but when I return it doesn’t work I have to manually go into the app and disarm the system, prior to the update it worked perfectly, I’ve tried to restart the system but nothing.
Can anyone advise if they have the same issue ? Or if there is a solution?
- Email to a Friend
Why do we need GPS to geo fence . Surely the connection to your home wifi is more reliable. Or a signal transmit by your base station.
- Email to a Friend
I'm tired of all the issues I'm experiencing with my Arlo cameras.
I have spent so much money into the different Arlo cameras I own, and they just suck.
The app keep sending me notification about movement, cuz it's in the armed state, and even though, both of the phones are in range (I can actually see that it states in-range, in the device list), the geofencing mode enabled the armed mode.
In addition, it takes several attempts to connect to two of my Arlo 2 pro cameras, that are located 40 ft from the base station. Cuz every other time I'm getting error playing, and when it finally connects, the lag is just unbelievable. Not to mention that I need to replace their batteries every 3 days, cuz they drains like crazy.
Already tried to reconnect them to base station, but it doesn't help. And also the smart zones are not helping maintaining battery life.
I'm really frustrated with it all.
Feels very amateur, and like there isn't a support behind it that actually fixes issues, but just r&d that keeps running forward to release new products.
- Email to a Friend
- Email to a Friend
Same issue here. This has been this way since the homekit fail last month.
- Email to a Friend
I have always assumed that Arlo uses the location services APIs for iOS and Android, so the interface is likely fairly straightforward. If they used WiFi SSIDs, they would need to narrow the range down to whatever the Wi-Fi coverage happens to be. For some people that isn’t even their entire home. Also, some people use extenders or multiple base stations with different SSIDs, so they would need to anticipate the use of multiple SSIDs. For people using Arlo devices in more than one home, they would need to allow for that. I believe location services uses a combination of GPS and Wi-Fi...possibly even cellular location information to improve accuracy.
- Email to a Friend
- Email to a Friend
Agreed, the geofencing has been erratic for about a week now. Is there any timeline for a fix?
@LodonArloUser wrote:
Looks like there must have been an update - because the erratic behavior with the geofencing is back.
Arlo - please please please get some proper testing in place.
- Email to a Friend
Arlo,
How difficult is it to send out a message stating you have an issue with Geofencing and you are working to resolve it. This would stop the numerous amount of users posting complaints and fruitless work arounds and give you a little crediblity as a company that cares for its customers.
- Email to a Friend
I can't seem to get my Geofencing / Schedule combination to work out.
I have my mode set to Geofencing where when I'm away, my three cameras (2 outdoor, 1 indoor) are set to armed. When I am home, I have it set to Schedule. I want to have it so that my outside cameras only come on from 12am-18am when I am home, but to leave my indoor camera deactivated to avoid notifications and records of me just walking around my house when I'm primarily awake.
To achieve the Outside only camera grouping, I created an Outside Only custom mode and only selected the outdoor cameras. So when I'm home and it goes to Schedule, I have my 12am-8am set to the custom mode Outside Only. However, it seems to still keep my inside camera still active as well because I'll still receive notifications from me inside. Any suggestions?
I've attached images of what set up I have.
- Email to a Friend
We have used Arlo for about 1 year with mixed success. For the past 4 months it seems to hve been really stable, but about 2 weeks ago the Geo fencing just stopped working, for no apparent reason.
Now even when its states both devices are in-zone, it still triggers everytime there is movement.
I've done all of the usual diagnotics. with no luck.
This makes the system, largely unuseable.
For saying how expensive this system is, this really is not acceptable.
Come on Arlo, get your act together!!
- Email to a Friend
I feel your pain. I think it's time for me to cut my losses and buy a new system 😞
- Email to a Friend
Just more problems with an already extremely frustrating product
- Email to a Friend
Sounds about right. It really is a frustrating system. I can’t believe there hasn’t been a class action lawsuit filed.
- Email to a Friend
- Email to a Friend
It appears the last fw messed things up with geozone... I would guess it's being fixed.
verify all settings are good on the phone and gps not going to sleep.... also try and enlarge zone area
- Email to a Friend
- Email to a Friend
Geofancing seems to have stopped working properly: when I leave my home it arms all my devices correctly, but when I return home it will not disarm anything. I have to disarm all my Arlo devices manually …and I have quite a few devices, it’s a real pain in the ~!-@#$%.
The only changes I’ve made to my system is, I’ve added a couple Netgear nighthawk range extender (ex8000). I’m not sure if this has anything to do with the Geofancing issues but it’s around the same time I started experiencing this problem.
Thanks for any help you could provide!
- Email to a Friend
- Email to a Friend
The extender shouldn't effect the geozone... but there is a posibllity of interfernce to the bases/ standalone cameras.
Only true way to tell is turn them off ( even one at a time if not both ) or move the bases away via temp etherent cable and then go for a walk/drive till the system arms, wait a min or so and walk/drive back
- Email to a Friend
Same problem here. Geofencing with Scheduling worked fine up until recently. Now when returning home the system sees that I have returned but it doesn't disarm. I need to maually disarm both base stations and then turn Geofencing back on. We have 2 iPhones geofnecing, iPhone 8 Plus and a 10. The Problem seems to only happen with the 8 Plus. I'm getting pretty tired of all the Arlo software problems. Time to quit causing problems for your customer base Arlo and Netgear!!!
- Email to a Friend
After about 20 or 30 attempts finally managed not to get a blank chat page. Chatted with a support person who said this has been rectified and went through a few steps involving changing the name of my phone. Of course it did not work. Now cannot get chat to work again, nor have they replied to two emails I have sent in reply to the email they sent me after the chat. Very frustrating.
- Email to a Friend
Ever since the last app update (5/25/19) Geofencing will not disable when I re-enter the zone. It will arm when I leave the zone but will disarm when I re-enter.
- Email to a Friend
Correction; the Geofencing failure occurs on both iPhone 8 Plus and iPhone 10. Just another Arlo software screwup. Are they trying to kill this product? They are certainly killing any customer loyalty they had...
- Email to a Friend
I've had a Netgear Nighthawk WiFi Router and a Netgear Nighthawk Mesh Extender for a couple of years and didn't have any problems with Geofencing until about a week ago. All these devices are Netgear so they better be compatible. Both the Arlo bases are hard wired so I can't imagine why a WiFi extender would mess them up? Probably purely coinicednetal but the base nearest our Mesh extender started to act up first and I thought the base was failing. I did a couple of resets on it but that didn't solve anyhting. Now both bases fail the same way everytime we return home. This just smells of poor software testing.
Dienste und Sicherung
FlexPower ONVIF Cameras
ReadyNAS for Surveillance
Switches For Surveillance
