I've tried a couple different POE injectors and adapters but none will charge the battery for the camera. So far they all end up with a message on the camera saying "The charging source connected to the camera cannot charge your battery...." Has anyone found a product that will charge the battery yet?
My Setup: Linksys MX10 on Frontier FIOS 500/500.
Also experienced with AT&T Fiber & Charter Cable
OK, So I found a solution to this problem and it is charging the camera over ethernet.
You will need one pair of these SinLoon(2-PACK) AF-RJ45 USB to USB Female to AF-8P8C Connector Crystal USB, USB Transfer Network Plu... These simply convert the power to allow it to go over ethernet with whatever charger you want to use and don't require a POE switch.
I then purchased a USB-A male-to-male cable and connected the Arlo charger to one end and the other end to one adapter. The other adapter connects to the Arlo USB cable and the camera at the other end of the ethernet run.
YMMV depending on the length of the ethernet run. In my case, the run is at least 50 feet to a storage closet that didn't have any electrical outlets.
Not really true....
The Pro and Pro2 use a Qualcomm type dual voltage charger. The adapter will put out 5v( stanard usb output) via the usb or 9v depending on what it is plugged into. You can NOT charge an 8.4v cell pack ( listed as 7.2v but charges to 8.4 ) with the 5v only and that is why it also puts out 9v.
If used in any other devices, the adapter should work as normal.... Also SOME qualcomm type charges will work with the cameras but not all ( voltage level is specific ).. I have tested my S7 phone dual voltage adapter and it worked fine for me on a Pro2. YMMV.
I'm looking at a POE solution for the Pro 2. Can you provide a link for the other items used? Also, not clear to me how you are interconnecting all these items to power the camera?
It worked for a few days but the camera has since started showing the incompatible charger notice again.
