Arlo Pro 2, can i control and view the cameras from a remote computer
  • 9 Replies
  • 6319 Views
Karol2
I didn't buy yet the cameras, i want to make sure i can control the cameras and view and download the recordings but from a remote computer, not the computer that is connected to the router to which the NETGEAR is connected.
In other words can i manage and view the recordings from a computer that is on an other LAN
9 REPLIES 9
You can control and d/l the videos and watch live from any computer / tablet / phone that has internet access....
I was able to watch my home even while at sea on a cruise.
Karol2
How do i do that?
The first time i install the cameras and the NETGEAR controller i use the computer at the home where the cameras are, i understand. i enter the site arlo.netgear.com and it searches the cameras.
But later can i use arlo.netgear.com to enter from an other computer?
If on any computer use https://arlo.netgear.com/ with your user name and pw...
OR
if on Ios or android phone , use the apps ( found in the stores )
Karol2
But the first time NETGEAR finds the cameras i must use a computer that is on the same network as the router NETGEAR is connected to, right?
esp if you are using a phone...
Yes.
Karol2
I made a mistake, i will probably buy Arlo or Arlo Pro.
Can i attach a fixed wire, AC or DC, to them, in order not to change batteries?
It's hard to adjust each time the angle
Is a transformator supplied, is there an inlet to the transformator in the Arlos?
Arlo cams use 4 - 123 type batteries and do not have an ac adapter option
Arlo Pro ( and Pro2 ) use a rechargeable battery pack and can be plugged into ac ( tho at this time there is no outdoor ac adapter as the previous outdoor one was recalled )
Check out the product info at the top of page and also check the FAQs as almost every question has been answered.
Karol2
I don't find a page for the base station, for which models is it suitable?
I think of buying Arlo Q or Arlo Q Plus, but i don't see in the manual that i need a base station.
So, if i use a mix of Arlo wire-free cameras, which need a base station and Arlo Q which don't need...
Is there only one model of base station? it is needed only for the Arlo wire free models Arlo, Arlo Pro?
Karol2,
Take a look here for information on each Arlo product. You can click the compare tool to see the differences of each camera at a glance:
Arlo Products and Accessories
