On othe Arlo app, for Android, when I have geofencing enabled I have a notification that states "Geofencing is enabled". I have push notifications turned off and I want to disable this notification as well; however, I still want to use geofencing. Any help is apprecaited.
Android 8.0.0
Arlo App: 2.7.0_23403
Samsung S8 Android version 8.0.0
Arlo 2.7.0
Screenshot of notification attached. If you swipe, it only offers the option for settings, where you can completely turn off all notifications. Not what you want to do with security cameras
Today I started receiving motion alerts that I also can't swipe away.
Galaxy S9
Same thing here. s8+
thanks for help
Has anyone seen this the notification go away yet? I still have it all the time and still unable to swipe it away. In a way I'm almost scared to mess with it too much because my system is finally working as desired (finally getting alerts for arm/home when on geofence) and everything else appears to be working. Just hate that I have this up on my phone all the time.
Hi everyone,
Our development team is aware with some users are unable to remove the notification when "Geofencing is Enabled" on the Arlo Android app and is currently investigating the issue. We appreciate your patience and understanding and will update the community once we hear more information.
Unfortunatley this isn't a problem on my iPhone. You can idividualy swipe and clear those geofencing notifications away. How does Android handle them - bulk ?
For Arlo, this is an issue if you are particular about keeping notifications clean, like I am, as I now constantly have an Arlo notification sitting in my top notification bar. My desired outcome is an icon of Arlo in my top notification bar means I need to go look at something. The only way to achieve this is by disabling geofencing.
Thank you for pursuing this bug fix! It's seemingly affecting many Android models.
Pixel 2 XL
Android 9
Same on my S8 - following..
This is always in the notification bar and cannot be removed. Quite annoying, only started after the latest update.
Also, when I enter/exit the geofencing zone, I get no notification of Arlo arming or disarming. However if I have the app open, it does let me know that Arlo has armed/disarmed. So if I want it to let me know, I have to drive away from my home with the app open to get the notification. Quite annoying!
Anyone else?
Following as well. Persistent "Geofencing is enabled" notification popped up this morning after rebooting my Pixel 2 XL running Android 9 with the Google Pixel January 2019 security update (PQ1A.20190105.004). Arlo app was also updated to 2.7.0_23403 last night. One or the other is now causing this issue.
Pixel 3
same issue. Galaxy s8+
Android 8.0.0
Arlo App version 2.7.0_23403
Android 8.1
Arlo geofencing enabled notification is pinned. Cannot swipe away. Every time I look at phone I see arlo notification icon and think there's a security issue at home. Poor software.
