On othe Arlo app, for Android, when I have geofencing enabled I have a notification that states "Geofencing is enabled". I have push notifications turned off and I want to disable this notification as well; however, I still want to use geofencing. Any help is apprecaited.
That must be something new, I have never seen that, but I haven't used geofencing in a long time. Anyway, go into android settings, notifications, arlo. You should be able to turn off all arlo notifications there (if that's what you want).
Also usually in android you can partially slide the notification to the right which will give you a settings gear icon which takes you directly to the arlo android notifications options.
Thank you for the idea. I tried that for a little while before I posted the original message, but when doing that it turns off all Arlo notifications, including the notifications that occur when the camera is triggered. I would like to be able to keep those notifications active, as those are immensely helpful.
Ok, sounds like a new "feature". Only thing I can suggest is post an idea to get it removed or at least an option to disable/enable it.
https://community.arlo.com/t5/Arlo-Idea-Exchange/idb-p/arlo-idea-exchange
Following as I now have the same issue.
And today it's gone and everything works fine. Go figure
Did you do anything to make it go away? Mine is still showing.
I also have the geofencing notification always showing with the latest update. Arlo's Android developers need to utilize Android's Notification Channels to seperate this persistant notification from the normal camera notifications. This would allow a user to turn off the geofencing notification without affecting all the other notifications.
Same issue for me.
Motorola Z2 Play running 8.0.0
My wife has an identical phone with the same issue.
Haven't been able to find a way to hide it yet.
Also extremely annoying because you can't remove camera notifications since this one is permanent. I need to clear all to get rid of camera notifications which is useless
Having the same issue. Using Pixel 3 with latest Android OS.
I don't want to disable all notifications for the App, but I don't want a constant notification for GeoFencing 😞
Same issue here. Very annoying since I keep my notifications clean.
You cannot swipe the notification. The only way to remove it is to turn off all Arlo notifications. This not a viable option if you still wish to be notified when entering/leaving the geofencing location or when motion is detected by one of your cameras.
Issue started after latest Pixel 2 XL Android update which I received today.
Hi @Dave32dmb and @Sanford87,
Are you seeing the same screenshot that tmmwt2 posted up?
And could you all let me know what phone device you are using and what Android version you are running on? Make sure you are on the latest Android Arlo app, which is 2.7.0.
I am using a Motorola e4 plus running Android 7.1.1. The version of arlo I have is version 2.7.0. I am still having the same issue as previously mentioned.
Putting the geofencing notification on a seperate channel would allow the end user to turn it off without affecting the motion notifications from Arlo.
Same here. I want to use geofencing and get notifications when enter and leave. I do not want the "Geofencing is enabled" notification that I can't swipe away.
