  • 2 Replies
  • 413 Views
Carin
I can not find a way to change the length of my video recordings. I followed ALL ARTICLES, FAQ, AND IT doesn't work. I need to talk to a real person . I received an email from an Arlo Guru but it just said My interface must be UI. That means nothing to me. Then he sent me a link to things that don't help me with video recording length. Virtual assistant is of no help as it just shows everything I have been trying to do. Version 4.13.2866 if that helps. If I don't get someone to help I will just cancel my subscription.  Thanks
That sounds a bit garbled.
When you open the app, are you seeing
  1. Menu options called "Library" and "Mode"?
  2. or Menu options called "Feed" and "Dashboard"?
ShayneS
HI @Carin
When you mention the feature doesn't work, what are the symptoms you're experiencing?
  • 2 Replies
  • 414 Views
