I cannot locate genuine Arlo Pro 3 batteries or dual battery charging systems in Canada. Please enable distribution of these products in Canada or allow shipping into CANADA from your US distribution channels.
( The knock off
Wasserstein
Products are substandard and don’t work properly.
Hi GMGK,
You can purchase the Arlo Pro 3 rechargeable battery (VMA5400) and Arlo Pro 3 Dual Charging Station (VMA5400C) through here:
@Lindsaycamero78 wrote:
Silly question mine are just 2 yrs old and 1 camera won’t even turn on. Should I replace the battery or just buy an outdoor cord?
Swap batteries with another camera, and see if that resolves the problem with the camera that won't turn on.
Did you let the battery fully discharge? It's best to recharge when the battery gets below maybe 25% (just look at the color of the battery icon in the app - red means below 25%). You can try this although it's for the Pro and Pro 2 cameras
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
Does the camera turn on with AC power applied? Some folks have found that removing the battery may be necessary for some reason.
