Arlo pro 3 not charging
  • 14 Replies
  • 25764 Views
  • 4 Likes
  • 9 In Conversation
NickJP
Plug camera in. Flashes blue light. Flashes blue again every minute or so. Will not charge .camera is 2 months old.
If you're experiencing an issue getting your cameras battery to charge, try following the steps in this article: My Arlo battery is dead; what do I do?
If you still experience the same behavior, please contact the Arlo Support Team to further investigate. You will find several options for contacting support in the provided link.
14 REPLIES 14
Did you totally deplete the battery so it's dead? If so, read the FAQ in the support area about reviving a dead battery. It's basically plug the camera in 6 times to get enough charge so it will then charge normally. If this is the solution, just charge your batteries more proactively.
NickJP
Usually charge around 25%. Battery is saying 8% on app. Been plugged in for over 12 hrs . No change in battery.
I tried resetting everything up. Base station is ok.( firmware updates fine and is set up) I Hit the (forget device) button for the 1 camera I have. It proceeded to search for camera.Tried to re-sync still can’t locate camera. It even flashes blue when sync in process on camera.
NickJP
Need help
NickJP
Did not work
Could be a hardware problem. Use the Contact Support link at the bottom here.
Jsam123
Be sure to push the black part of the camera all the way in the casing so to contacts line up!!
PaulTu
I have had my cameras about 6 months now and this is always a problem.
It’s a major Arlo issue!!
Shaun1234
Virtuoso
Virtuoso
You probably are put just to check you are only using the Arlo plug and lead that it came with, as I had a similar issue and I was using a after market lead which didn't supply enough volts
Bc1939
ARLO camera not charging
PaulTu
This is not the issue.
dcfox1
What is your issue? You never gave any details.
PaulTu
Took the cases off my cameras and attached the charger to the contact points with a rubber band. They now charge.
Ridiculous that I have to do this every charge but it is a solution.
Maybe a re-design by arlo next time, as it is a wide spread issue.
genxmatch
I agree its a design problem..this is how im charging my Arlo Pro 3 Camera now...never fail this way...Arlo, this is pretty depressing
  • 14 Replies
  • 25765 Views
  • 4 Likes
  • 9 In Conversation
