If you're experiencing an issue getting your cameras battery to charge, try following the steps in this article: My Arlo battery is dead; what do I do?
If you still experience the same behavior, please contact the Arlo Support Team to further investigate. You will find several options for contacting support in the provided link.
Did you totally deplete the battery so it's dead? If so, read the FAQ in the support area about reviving a dead battery. It's basically plug the camera in 6 times to get enough charge so it will then charge normally. If this is the solution, just charge your batteries more proactively.
I tried resetting everything up. Base station is ok.( firmware updates fine and is set up) I Hit the (forget device) button for the 1 camera I have. It proceeded to search for camera.Tried to re-sync still can’t locate camera. It even flashes blue when sync in process on camera.
Could be a hardware problem. Use the Contact Support link at the bottom here.
It’s a major Arlo issue!!
@PaulTu wrote:
This is not the issue.
What is your issue? You never gave any details.
Ridiculous that I have to do this every charge but it is a solution.
Maybe a re-design by arlo next time, as it is a wide spread issue.
