Re: VMB4kr3 firmware update v1.14.1.0_2909_bfcf6... corrupting operational settings.
- Email to a Friend
System is a complete POS.
Is anyone else missing the "Add Device" button in rules for cutom modes?
- Email to a Friend
ROLL BACK ARLO, QUICKLY!
- Email to a Friend
I'm having the same problem the last two days. Right now, the mode isn't showing up on my Android app. Yesterday, it showed up, but I couldn't change the status.
This isn't an app problem, this is a server problem. Arlo?
- Email to a Friend
Having issue wit motion detection - keep turning down the sensitivity on cams, but it keeps triggering and the tiniest movement, like it's ignoring my settings, completely. And I rebuilt all my custom rules, so can't blame it on firmware-borked-up-rules, either. And yet? 3 of my cams that face the street (within 20 ft of street) 8 times out of 10, 1 or 2 of the 3 cams will MISS DETECTING vehicles as the role on by. And I am not using Arlo Dumb, either.
- Email to a Friend
- Email to a Friend
- Email to a Friend
Yes, that is one of the many results of this botched firmware update.
Indeed I had spent a great deal of time creating for my “night” modes some very effective integrations between my Arlo cameras and the Arlo lights. Any mode that had such an integration disappeared and now they can’t be recreated.
Oddly a few times earlier today the modes came back briefly on 1 of my 4 base units, but then disappeared. When that happened the integrations with the lights were there, but I could not edit them. So who knows what kind of things they are trying on the cloud side.
Perhaps almost as disappointing as this botched base station update is that there has been no notification to customers of even a “sorry, we are working on it.” They have all of our emails . . . . .send us a message or putting a message up on the boards would seem minimally the polite thing to do. There status page indicates everything is fine. . . .obviously NOT!
- Email to a Friend
- Email to a Friend
The problem has come back. I lost the Connectivity between my Base Station and my Cameras and like others the signal strength has been reduced when it did come back yesterday. Also frustrated after trouble free service and whilst I understand mistakes happen when they do Netgear need to tell the community there is a problem so we can be assured this will be resolved.
At the moment this entire poor Customer Service is putting me off Netgear big time. Netgear is my go to brand for Routers, switched, security products etc. but based on the appalling response to date I will have to switch to other Companies that put the Customer first.
Arr NEtgear going to actually tell people (a) what they are doing and (b) if there is a single workaround because so far the recommendations from Support vary. Not blaming Support I expect they are in a communication vacuum like the rest of us.
- Email to a Friend
Problem is not resolved. I have two base stations (one with 2 cameras and one with 3 cameras). The 2 camera system is working fine whilst the 3 camera system keeps having the cameras disconnected from the Base Station and when it was working it was not recording all activity.
Both systems are the same models of equipment and they are on the same hardware version. There is no special setup (it is all default) so I do not understand why one is working okay and the other is not.
- Email to a Friend
You can somewhat work around it, or at least I have, deleted all the junk modes that the update replaced my modes with. I then programed the cameras indiviusually, then instead of the old "add Device" button, I wrote "When Cam 1 detects Motion, Cam 2 records and such. So now I have the same modes and rule just a pain programing all those rules seperatly
- Email to a Friend
- Email to a Friend
Yes, but while that may give you some functionality back between cameras all of the interactions we had for cameras triggering Arlo lights are gone.
They have not only broken many things they have killed features they made a big deal about the benefits of when introduced.
- Email to a Friend
After the last update, the system has been completely corrupted. All my rules are gone and cannot be set again properly. Moreover, the signal strength between the base station and the cameras is very low. And, last but not least, the app on iphone X does not support the face ID anymore. What is going on here? 800€ for a system which collapse completely after a simple update? Unbelievable!!
- Email to a Friend
Modes are messed up. Created new ones on my iPad but could not engage siren. Went to web page on MacBook and the siren shows as on??
old modes failed to save and gave a error hence new modes and they had altered which is strange.
reminds me of Windows 3.1.
- Email to a Friend
See attached. Used to be able to add a trigger for recording from another camera? Seems the latest update or changes to the free subscription has changed to allow actions for only one device per rule?
Might be an error from a conflict when updating rules/modes created in the past version of the App?
- Email to a Friend
I no longer have confidence in Arlo to be a reliable system for home monitoring. I cannot count on system alerts from Arlo in a timely manner when system issues are suspected, being addressed, or resolved. Even an antiquated system like Motorola sends system wide alerts when issues are identified and when resolved giving the user confidence in the equipment.
Arlo customer service has been unreliable and regardless of issue results in requiring user be present at the residence/business, user to uninstall/reinstall one or several cameras (hello ladder), and then uninstalling/reinstalling app....all which typically may/may not resolve issue.
So disgusted in Arlo and crazy that for price, on three seperate occasions, Arlo has been unavailable, offline, or unreliable, and Wyze has been our go to. Why again are we using Arlo....???
- Email to a Friend
- Email to a Friend
Code 4000. I notice many people with the same issue. We just had an update on our base stations. An acknowledgment would be appropriate. Thanks.
- Email to a Friend
- Email to a Friend
- Email to a Friend
- Email to a Friend
- Email to a Friend
- Email to a Friend
After last update i have 3 big problems!
1st is that the siren cant be activated. It is missing in the settings.
2. I can no longer start to record from cameras from the other Base when something happen on one set of cameras! I want everything to be more connected not less. I have two houses on the yard which means i want tw bases so I can have the alarm in both houses also i want my cameras be connected to the Base closest to the it.
3 my setups has been removed... How can arlo fail so bad in an upgrade. Now I am going to be worried about the stability of the system when I am on vacation next time.
