Hello.
Is it me or is iOS app missing icons to show fully charged batteries and AC power connected icons for Arlo 2 Pro cameras? I do see an icon for disconnected cameras using their batteries and connected charging batteries. This is in iOS app on iPhones. I see the correct icons in web site version though.
Thank you in advance. 🙂
@ant wrote:
Weird. https://www.reddit.com/r/arlo/comments/7vi4bq/no_fully_charged_batteries_and_ac_connected_icons/dtt0... says no problems in Geo38's iOS devices. So, why do only some users see this problem?
I use an old G2 or 3 ipad... ios 935.
Some use newer versions which now run ios 11+
It has been prev reported and is known there is a bit of non-same icons accross platfroms.
IOS fails to show the lighting bolt ( iirr ) on a fullcharge battery while the web and android does.( in charge mode/ac )
@TomMacwrote:It has been prev reported and is known there is a bit of non-same icons accross platfroms.
Thanks. I hope Netgear fixes it soon since it is confusing! What's IIRR?
Tom's old and uses IIRR (If I Remember Right) instead of the more common IIRC (If I Remember Correctly).
