Arlo Pro 2 with solar panels - one camera is not charging the battery
  • 1096 Views
jac9281
Three of the cameras with a solar panel attached keep the batteries close to 100% charged all the time.  One camera, at the front door, drains a fully charged battery quickly and does not charge it.   Is this a known problem for some cameras or panels?
Arlo Pro 2 VMS443OP-100NAR
jac9281
Swapped one the other day & the battery on the front door camera began to charge.  The other camera & battery seem to be doing fine too.  Thanks for the idea.
What happens if you disconnect the panel? Have you swapped panels (or cameras) around to see what happens? There have been cases where a faulty panel have caused battery drain.
jac9281
Good idea; I will look into this.  My problem is that the other three cameras are very high and I am too old to climb ladders any more.  I can get to camera by the front door but I will have to get my handyman over to experiment with your idea.
jac9281
  • 1097 Views
