About two weeks ago, I charged the battery of my camera when it was at 60%.
Now, the indicator is still reading 100%.
Usually by now, the camera battery would be at 90 or 95% charge.
Do you have any news from Arlo?
Hi MPhil,
Have you tried removing and re-inserting the battery and see if the indicator shows correctly? Is this showing on the Arlo app on your phone and/or the web client on your computer?
Hi MPhil,
Hi JessicaP,
I will try to remove the battery and reinstall it tonight.
Yes, it reads 100% on the phone app and web client.
I will report back asap.
Thanks,
Phil
Hi JessicaP.
After removing and reinstalling the battery, it looks like it's working now.
Thanks,
Phil
						Arlo Mobile App629
						Arlo Pro 211
						Arlo Smart180
						Before You Buy995
						Features441
						Firmware Release Notes57
						Google Assistant1
						IFTTT (If This Then That)24
						Installation1,148
						Online and Mobile Apps865
						Service and Storage317
						SmartThings37
						Troubleshooting6,322
