About two weeks ago, I charged the battery of my camera when it was at 60%.
Now, the indicator is still reading 100%.
Usually by now, the camera battery would be at 90 or 95% charge.
Do you have any news from Arlo?
Hi MPhil,
Have you tried removing and re-inserting the battery and see if the indicator shows correctly? Is this showing on the Arlo app on your phone and/or the web client on your computer?
Hi MPhil,
Hi JessicaP,
I will try to remove the battery and reinstall it tonight.
Yes, it reads 100% on the phone app and web client.
I will report back asap.
Thanks,
Phil
Hi JessicaP.
After removing and reinstalling the battery, it looks like it's working now.
Thanks,
Phil
