I just got an Arlo Pro 2 2-Camera system 2 days ago and I noticed that while live streaming and when motion was detected I get a "The Request Timed Out". Seems not right. Camera signal to base is strong, 3 bars. I've a 200MB up/down internet connection
Also, all the custom modes that I created the day before disappeared after a few minutes of trying out Arlo Smart. Both on web interface and app. The default modes were messed up as well (Armed - motion detection turned to audio). I've reset Arlo base and reconfigured my modes. Is this common with Arlo? All this issues on 2nd day!
same thing happens to me. Good luck, Arlo's are buggy as can be. You learn to deal with it
So the modes disappeared again.... This was when I noticed 1 of the Arlo Pro 2 cameras wasn't getting triggered by audio/motion. I disconnected/reconnected the battery then the custom modes I've set last night, after doing a factory reset on the Arlo base, were gone again.
Have you applied pinch and zoom to any of your cameras?
On the camera that wasn't triggering; Basic Zones, yes. Pinch and zoom, no.
https://community.arlo.com/t5/Arlo-Pro-2/Arlo-pro-2-mode-and-schedule-settings-continue-to-be-delete...
https://community.arlo.com/t5/Arlo-Pro-2/Arlo-Pro-2-Cam-Externally-Powered-Lockup-s-amp-Encoder-Erro...
Ahhh! Yes! it's somewhat similar to this. God forbid the siren don't get activated when motion is detected when another random mode gets armed!
As for the custom modes disappearing/deleted/changing, is it the "Scheduled" mode that's messing it up?
The work around for me is to delete all activity zones from your cameras, be aware that deleting them will also cause the settings to be changed, so you will need to add them back again. Then keep an eye on the camera settings to make sure they do not reappear by themselves.
This is frustrating
