arlo app crashes and the video time stamps are incorrect. The sound from a watched video continues playing even after I close the video. The function buttons in landscape mode are way too small. Previous versions were very user friendly. Not at all usable or stable enough to function as a security device. I have contacted cus support numerous times and no results or remedy. My arlo pro 5 cam system wasn't cheap and I would expect better care of myself and other users alike.
Hi Me3,
I have a few questions for you. What device & Operating system are you running? You may need an update. Can you try and uninstall and reinstall the app and test again.
I have the app on 3 Android devices with the OS varying from 5.x to 8.x and it works fine. Sounds like somehow it's a local issue. WHat device and OS? Do you have another device to try (maybe borrow a friend's and temporarily install the app)?
