Why Cant I Stream On All Of My Cameras?
  • 1 Reply
  • 949 Views
Richardcabrera
I purchased 2 arlo pro 2 systems and 1 arlo pro system for my place of business. So far what a mistake I’ve made. I keep getting mixed information from the tech support in India . First i was told that if i pay for the Elite monthly program i can stream live 20 cameras when it wasn’t working correctly I was told that i can stream 5 cameras per hub base. So i installed another hub base and paired  the cameras. I still can not stream and see the 9 i have installed at once even using 2 base stations. I still have 3 cameras to install and 8 more i wanted to add to my system but it looks like if i cant get good tech support to help me with this issue i will be taking all 3 (4) camera systems back to Best Buy and lodge a complaint with them for misleading information. The concept was a good idea but arlo is not up for professional grade cameras
You may be expecting something that the system was never designed for. These are not for constant streaming but for motion detection recordings. While you can live view, it will time out due to battery constraints. It would seem what you want is a wired system which likely cost you many thousands of dollars.  Verify your expectations and compare to the capabilities of various systems for the best choice. One size doesn't fit all.
  • 1 Reply
  • 950 Views
