- English
- Services
- Arlo Home Security System
- Re: Arlo Keypad Sensor Hub will not connect to my ...
I just purchased an Arlo Keypad for my security system. As I am adding the device to my app, it will not recognize the network. (it sees other networks just not mine) Yes, it is a 2.4ghz wifi. I have tried restarting the keypad and creating a guest network, I've restarted my modem, and I have even added the MAC address to my router. I have tried different devices like trying to set it up on my iPad etc. I contacted support but they only suggested the thing I have already tried. I'm operating an iPhone, Ipad and Century Link C3000Z Modem... has dual channels so it has a 2.4hrz, and a 5.0hrz
If there are any other suggestions, I would greatly appreciate it.
#arlohomesecurity
**Update**
I was able to connect to my 2.4 wifi when I disabled my 5.0 wifi. I logged into the router and turned it off. It then showed up on the hub... SUCCESS!
Noah_
Is your router set up to use WPA2 or WPA3? We recommend WPA2.
Yes, I have WPA3
Noah_
This could be the reason you're experiencing an issue. Try switching your router to WPA2 and then attempt onboarding again.
**Update**
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
