  • 4 Replies
  • 4691 Views
Noah_
I just purchased an Arlo Keypad for my security system. As I am adding the device to my app, it will not recognize the network. (it sees other networks just not mine) Yes, it is a 2.4ghz wifi. I have tried restarting the keypad and creating a guest network, I've restarted my modem, and I have even added the MAC address to my router. I have tried different devices like trying to set it up on my iPad etc. I contacted support but they only suggested the thing I have already tried. I'm operating an iPhone, Ipad and Century Link C3000Z Modem... has dual channels so it has a 2.4hrz, and a 5.0hrz
If there are any other suggestions, I would greatly appreciate it.
#arlohomesecurity
Noah_
**Update**
I was able to connect to my 2.4 wifi when I disabled my 5.0 wifi. I logged into the router and turned it off. It then showed up on the hub... SUCCESS!
Noah_
Is your router set up to use WPA2 or WPA3? We recommend WPA2.
Noah_
Yes, I have WPA3
Noah_
This could be the reason you're experiencing an issue. Try switching your router to WPA2 and then attempt onboarding again.
Noah_
**Update**
