Tomo15
  • Why am I all of a sudden receiving “critical battery warnings” when my battery is 90% charged and connected to a solar panel?  Never ending issues with this very expensive camera.
Best answers
  • ShayneS
100 REPLIES 100
matt2023
Perhaps it's the Arlo millennium bug! Something to do with a date.
amanda14
Yes I am getting critical battery alerts for all 4 of my cameras which are fully charged, I spoke to support and we could not fix it, iv tried everything but the messages come every few minutes all night and day for the past 4-5 days!! Why? Is it since the last update of the app? Please help!!!
amanda14
amanda14
Has anyone bothered to contact support to open a bug?
Use Settings, SUpport to contact official support. You need a subscription for this to work so purchase a single camera sub and then cancel when done.
skitkamera
Hi, yes I have been in contact med the support twice.
So faar the issue is still there....
skitkamera
...and the inbox of my email is growing all the time with this messages...
I must say that this camera has not fullfilled my wishes so faar. Beside this issue it goes offline very often.
Theese cameras are not the cheapest in market so I did not expect so much troubles...
skitkamera
Is it possible to downgrade the software ?
I think the software can be the problem.
mcjg
Can anyone who has generated a case with Support let me have the case numbers? I will raise them all again with them tomorrow. This problem is widely reported across the Net so may affect all Go users.
mcjg
I have had 14 replies to my post all with the same problem all started 3 or so days ago. Can you find out if there was a software change which may be causing it?
amanda14
Yes have raised a case, thought it was just a simple sign in and out of app, but didn’t fix problems
amanda14
mcjg
Amanda, do you have a case number?
skitkamera
Hi "mcjg"
I got this case number: # 00507169
I am waiting for a answer / soloution from support.
amanda14
amanda14
amanda14
Hi hoping that it has been rectified as I haven’t received any notification for a couple of hours 👍🏻🙏🏻
amanda14
 thought it was resolved but nope, coming again 🤷🏼‍♀️
Rokshok
Still.. the Battery Warning keep coming...
keryn
Thank you
tullyw
I am receiving these too. Batteries are fine, getting critical battery notifications every 10 minutes or so. Fix it ARLO!
Dpgsgp
Same issue.
Cazz1
Also same alert, once subscribed then what please
Rich_D
official response from Arlo Support
1. Un-install and re-install Arlo application
2. Please remove the Go camera and perform a reset on the camera and monitor it for 24 hours,
Great, except I am 45 minute drive away, and there does not seem to be any remote way to complete step 2
