Have essential pro.
How do I turn off animal detection.
Now have a guard dog.
Ta
To better explain..I just can't find the settings area to turn this off..just need step by step.
If you see "Library" as an option in your app, then use this guide:
If you instead see "Feed" and "Dashboard" then use this:
Thanks Stephen.
Have deleted the setting but still getting emails saying an "animal" detected on a camera.
Have even turned off motion.
How does that happen..?
Do you have all other motions turned on? If so can you turn them off just to see if you get the same behavior. Please let me know after you have done that.
Have everything turned off except person and audio.
Ta
The smart notification settings only apply to push notifications - not email.
No idea why that is, and IMO Arlo should fix it.
Agree Stephen...getting rid of arlo emails every morning is the whole reason I took it off the Animal setting.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
