Help
Hi just wanting to no can I connect my base station straight to my router?It is connected to my modem at the moment and it seems to go off line a lot was wondering if it would be any better going though my router.And this new app is horrible.
It sounds like your "modem" might actually be a gateway (modem+router). If it was a pure modem, then you'd only have one ethernet port on it.
You can check this by looking at your router's WAN IP address in its web ui. If it is private address (192.168.x.x, 10.x.x.x, 172.16. 0.0 to 172.31. 255.255) then you definitely have a gateway. Assuming that is the case, then you are actually double-routing. That isn't a problem, though it would add an extra step if you ever want to do port forwarding.
You can connect the base to an ethernet port on your router instead. That should improve your performance some when you are livestreaming the cameras.
On the off-line issue - how close is the base to your router? If it is too close, then the signal from the wifi can overload the receiver in the base (creating interference). It's good to put the base as far from the router as the cable will reach.
I have a router were the fibre comes into house then it has a separate modem,my base station gos to my modem not the router,can the base go directly to the router?
I answered this already
But I think are you confused on what you have. Can you give me the manufacturer/model for the modem and also the router?
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
