So I purchased 4 last week - installed all of them, and they’re working perfectly.
Purchased three more in a three camera pack. Not a single one of them will connect to any of my networks. Meanwhile, my original 4 continue to work flawlessly (so I’m guessing I have a functional 2.4 network and I’m connected to it).
Why can’t the same network see the new cameras? Password is correct and verified. Nothing I do works. Please help
9 REPLIES 9
Are you choosing the proper Essential camera when starting setup? There's the plain Essential and then there's the spotlight version. Try a reset of one camera to see if that helps.
Thanks - yes I’ve done those things. I even tried doing the other type of essential camera in case I wasn’t reading it right. I’m not getting this one - the others were so easy and have worked flawlessly.
Is there a VPN in use? If so, disable it.
There is no VPN. My modem has private browsing mode, which was active when I hooked up the others without issue. I disabled it but still no luck. I appreciate your responses 🙂
Try the web client on a computer to see if that helps.
Thanks - assuming you mean set up on a laptop instead of my phone? Via the Arlo web site? If so I’ll give that a try.
Blakesfav,
Yes, trying a different device to set up, such as the laptop, is a good alternative. Be sure the laptop is connected to your 2.4GHz WiFi band and try going through onboarding from https://my.arlo.com/#/login
Well I’ve tried every suggestion - laptop, rechecking passwords, tried three different networks, done everything. Nothing. Meanwhile, the first 4 I installed are doing great. Makes zero sense. I have to be missing something, but nothing has changed since I installed the first group.
And the mystery only deepens. I just set up an Arlo Pro camera without any issues. On the same network.
I then made three more attempts to set up each of the three in the pack. Zero. I can only conclude that this group of cameras is somehow programmed improperly or defective. I’m going to return them and start over.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
