- English
- Cameras
- Re: Camera will only take Snapshots after charging...
I recently charged my Arlo Essential, actually only second time I've charged it, but now it will only take snapshots. I turned off auto-low power mode and set the video quality to best. The routine is setup to record. Can't figure out what else to change to make it actually record video again. Snapshots are pointless.
Have you checked your modes and rules? If that's not the issue, try removing the camera from your account and add it back. Any better?
Yes, per my description, I checked and adjust modes and made sure rules were set. Neither should have changed since all I did was charge the camera. If saying I need to disconnect it to make it start recording video again is honestly a bull**bleep** solution. All I did was charge the damn thing, have never had this happen with any of the other cameras I own.
Why would charging it cause me to have to remove it and add again? I'm not going to do that cause I don't want to have to do that EVERY TIME I charge it.
Are you still seeing this same behavior?
I am having the same problem. The camera had went dead and after recharging, all we get is snap shots. I too have looked at all the settings and do not know what is causing this behavior. I have looked at the live view several times and that appears to be working properly, just not the recording upon motion. I have not taken the camera off of the account and readded.
@Tiger4Life can you dm me the serial number of the Essential 2 that you are seeing this on.
@joed_cny can you please dm me the serial number of the device you are seeing this with as well.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
