- English
- Arlo Forum Discussions
- Partner Integrations
- "Not Responding" message from Google Assistant; un...
I'm trying to link my Google Home Assistant devices (Chromecast and Google Home Hub) to my 3 Arlo cameras. I was able to link my Arlo Account in the Google Home app, and the camera names show, but when you attempt to open a camera it says "Not Responding".
I've tried unlinking and relinking my Arlo Account multiple times and it still will not work.
Why won't this work?
The only thing helpful anybody can post at this point is to post your stuff for sale on eBay and buy something else if Home/Nest is that important.
If the mention of Home/Nest magically disappeared, then would you too? Sell your cameras maybe?
https://youtu.be/-pHxDxQSazk
You are correct. Many people with these problems. I am still unable to view any arlo camera in the Google Home/assistant app. I have done everything suggested multiple times and completely reset and started over twice. Very disappointing for such an expensive product. Due to this problem, and the extreme lag in seeing the video even in the Arlo App, I personally will not be buying any more Arlo products and would not recommend to anyone.
What I want to know is why it does work on many android TV devices but not the phones. I have a few odroid boards and I have seen it work on that port of the O/S
https://m.facebook.com/story.php?story_fbid=446781829521845&id=257146888485341
I know there are similar threads to this one out there, but I wanted to share my issue specifically, and hopefully get someone's attention to this issue.
I have an Arlo Pro 2 with 5 cameras and 2 Arlo Q cameras. I have really liked my Pro 2 and Q cameras for the past year and a half I have had them.
Recently, I ended up with the Google Pixel 3 phone, and began to integrate my smart devices and apps to my Google Home app. I found that I was unable to stream my cameras through the Google Home app, and began doing some digging. I had been running my cameras through a Netgear wifi extender, as the base location was not best suited for where my wireless router was located. I thought the reason I was unable to stream through the Google Home app was because technically, my Google Home was running on my primary wi-fi "Network" and my base station was running off the extender "Network-ext". So I decided to invest in the Google Mesh wifi system- which has been awesome, btw. It also allowed me to hard-wire my base station into one of the "pucks", and I thought for sure I would be able to stream my Arlo cameras to the Google Home app finally. Well, turns out I still can't get this feature to work. It does not work for my Pro 2 cameras or my Q cameras.
I can get my Arlo cameras to stream to my chromecast on the TV (albeit rather slowly). But it still will not stream at all through the Google Home app. Is this a problem with everyone's Arlo/Google Home setup, or is it unique to my set-up somehow?
I appreciate any insight. It is in the grand scheme a minor issue, since I still stream through my Arlo app, but for the amount of money I have invested in all of these products, I would expect to be able to stream through my Google Home app directly on my phone.
I appreciate any insight or help.
IT WORKS NOW! I just changed to a Samsung S10+ (I really HATE this phone, will trade for the Note 10+) and it all works just fine in the app, HOWEVER, now I cannot add any new services to the app, I click the add "works with Google Home" prompt, and nothing happens.
The S10+ is a step down from my Note 9 in so many ways, and after 4 hours with it, I am not settling, I am going to get the Note 10+
I managed to get the cameras showing up in Google Home app for me, albeit intermittently.
- Once you've connected Arlo to Google Home, make sure you speak/type 'Sync my Devices'
- You should see the Cameras appear in the Home app.
- Create a room for your cameras, i.e. External Cameras
- Add the cameras to your home and to the new room.
- A new button in the Google Home app should appear that says 'Cameras' on it, which will give you links to your select a Camera.
- Now open the Arlo Web Portal, and view one of your cameras.
- Select the Camera in the Google Home app to view and see if the camera becomes visible.
- Now when I choose a camera to view it will show within 5 -7 seconds, if it doesn't then I go back and try it again.
FYI: This is with Arlo Pro 2 cameras on an Ultra Base Station
I think the integration has trouble initializing the cameras which is why you get a not responding message, as there is probably a response timeout that Google Home is looking for. That's what I've found so far. Not great, but it's something.
G.
yes, every now and again I can get 1 of my 3 cameras display in Google Home. it could be any one of 3 and that can be after viewing in Arlo app, or not. I tried it after an Arlo App update recently and 2 of the 3 cameras displayed in Home, I thought "Hooray, were in". yeah, nah, haven't been able to do that again, and in actual fact status quo of nil displaying is the norm. So still we wait 🙂
Indeed. It's still very intermittent, but what I was sharing was the steps that make the camera appear for me every time. As long as the cameras are in a room in the app (that seemed to help as well) and if the camera doesn't come up after 5-7s I hit back and do it again immediately then the camera shows. It confirmed for me the idea that the issue is likely around the lag/timeout for Arlo starting the stream.
Out of nowhere, my cameras starting working on Nest Hub Max, Nest Hub and Chromecast. No solutions posted worked for me, it simply started working one day. All camera firmware and apps updated, logged in and out of Arlo, reset, blah blah blah. The only thing I can think is either how I asked to see the camera "see below", or possibly uninstalling and reinstalling a different account (Hue, Wemo, etc.) or other unit connected to my system. I had seen somewhere that the Nest smoke dectector doesn't install if you already have a Nest hub Max installed, so maybe it had something to do with a conflict with other product. Either way, this shouldn't happen or be a problem for people.
The only possibility is asking to stream the exact name of the camera as follows. I have a camera called 'side door' one called 'front porch' and 'back porch'. If I say, " hey Google, show side door camera", it works. If I say "hey google, show side door cam", it doesn't. I have two Pro cams and one Pro 2 camera.
I have a Chromecast on my living room T.V. It is labelled 'living room Chromecast'. If I say "Hey Google, show side door camera on living room Chromecast" it works.
I tried so many different 'solutions' that never worked, I honestly don't know if when I first tried to stream I used the word 'Camera' or said 'Cam'.
I hope this helps, but seriously, with so many problems, with Arlo and Google Home. I think it is a disservice to say it works with Google Home. Especially with the high cost of the cameras. It should work flawlessly.
Still no solution - very frustrating that Arlo are still saying that it is supported. It may work, but the next time you try to stream it does not work....
Things seem to be working again for me now, and I can stream from both of my Arlo Pro cameras using the Google Home app on my Pixel 4XL. Given what others are saying, I'm doubtful it will stay this way for long!
some interesting info:
I also bought a Google Home Hub and link with Arlo Pro2, seems all fine BUT!
I can only see the stream on Google Home Hub IF I logged in into Arlo App on my iPhone or Arlo Web Portal.
And I also have to play streaming video on Arlo App or Arlo Web Portal.
THEN I can command Google Home Hub to view live stream.
hmm..... I wouldnt call it problem solved because I dont thing anyone will have theor phone open Arlo App or Web Portal streaming video 24/7 in order to get Google Home Hub to work......
Oh, if I logged out / quit the app / close the window on the Arlo App or Web Portal, Google Home Hub stream video will stop working as well, feels like it logged out as well....
This issue is still ongoing and after an hour on the phone with Arlo support their best answer was that I had to plug the google hub into the arlo base station with an ethernet cable (obviously no ethernet cable port on the google hub anyways). Sad to see that the problem has been going on for so long and on the two phone support calls I made they acted like this has never happened before. I bought the 6 camera arlo pro 2 pack with the understanding that it worked with google but looks like the option is going to be nest cameras since arlo doesn't seem to be working or responding on this issue.
AppleTV
33 -
Samsung SmartThings
87 -
Security System
