- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Can't connect to Google Home assistant
Following the instructions outlined here to a tee. Try as I might, I am unable to connect Google Assistant to my Arlo account.
At step "7. Sign in with your Arlo account.". After signing into my Arlo account, an "Account now linked" webpage appears in simple text for barely a tenth of a second before I am returned to the selection of smart device brands and a message appears briefly (about half a second) at the bottom of my phone screen stating "Couldn't update the setting. Check your connection." see screenshot below.
I have tried renaming all my Arlo Cameras and the Hub to simple one-word labels.
I have also tried deleting my entire Google Home profile and setting it up from scratch.
I have tried dropping my phone off the wifi network and onto cellular to perform the account sync.
I have reset and reconnected my Chromecast (Gen 1).
Everything is setup fairly stock standard and all on the same network.
The firmware on all devices are 100% up to date.
It's really starting to frustrate me and I'm starting to wonder if the issue is more widespread at the moment?
The problem magically did go away for me as far as linking up the Arlo to google home. I can see my camera listed and assign it to a room and thats as much as I can do. I can't view the camera or play it to my TV. I get a "Not responding" message.
I guess thats some progress, but still not working.
For months I had Arlo linked just fine to my Google Home via Google Assistant. But I guess reading around the web there was some Arlo update (?) that boinked the whole thing up and now I can't link my account to Google Assistant. Every time I try it says "Couldn't update that setting, check your connect". I've tried via my Google Wifi Mesh internet at home, I've tried using just my cell connection 4G LTE, same thing. I've tried everything other than deleting the app from my phone and reinstalling.
I know it's an issue on Arlo side based on what I've been reading and wanted to know if anyone has had any luck resolving?? Like I said earlier, I was able to link Arlo to my Google home with no issues several months ago, but in last month or so, the link was removed and now I can't connect the two systems.
Any help is appreciated!
Well, this is definitely "any" help. It is not for the exact same issue, but close, and perhaps you could try it. Delete your cameras from your Home, or Homes. Unlink you Arlo account from Google Home if it is there. Go to the Arlo app and rename your cameras. Try to link accounts and see if things begin to show up.
Well wish I could delete my cameras from my Google "home" but they don't exist there anymore. They disappeared I guess when Arlo did updates.
And as I mentioned I can't even link Arlo to Google so nothing there to unlonk. 🙂
I can try renaming things and see it that helps.
UPDATE:
Changed names of camera, went to Google Home Assistant and tried to link Arlo. No luck. 😞
I am still unable to connect arlo to google home.
any update from the technical team?
Just bought an Arlo Pro2 with 4 cameras.
When I try to connect to Google Home, I get authorize the connection on oauth.arlo.com.
It then says Linking to your Arlo Account, then I get an error message at the bottom saying: Couldn't update the setting. Check your Connection.
Pretty frustrating situation - looks like this has been an issue for over a month on this board.
Any update from Arlo Tech support on a potential fix? If not I'm going to return the Arlo Pro 2 before its too late.
I have the same problem. My Arlo worked for about a day. I hate my Arlo,
wish I bought nest
I am having same exact problem
ARLO PLEASE GET THIS FIXED! Google support has stated (when I did online chat) that the issue is on your end, not a Google issue.
I bought a NEST indoor cam 3 pack, integration is excellent with both google home and Alexa.
Hopefully Arlo can clean up their integration story soon.
UGH!
Arlo finally updated their app and I got jazzed up that the supposed" bug fixes" fixed the Google Home link issue.
NOPE!! Still broken.
COME ON ARLO, FIX THIS ISSUE!!!!
I tried that trick early on. No luck at all. Same exact error.
I’m not sure how or why, but when I was at work with my phone on a different WiFi, the adding of Arlo works perfectly in Google home.
I still have the conflict (seeing the cameras twice - which causes google hub to recognize either). when I added the SmartThings Hub to Google Home.
So for now, I am not integrating my Samsung Smart Hub with Google Home.
With arlo alone in ten google hour, I am able to see live video from my cameras on the Lenovo smart display.
However, none of my IFTTT is integrated. Like automatically displaying camera when motion is detected. That’s kind of the reason I got the display.
I was so excited to see Arlo app was being updated today. Sadly, the supposed "bug fixes" diidn't fix the broken Google Assistant link issue!! ARGGGGGGGGGH!!!
COME ON ARLO, YOU KNOW YOU HAVE AN ISSUE...FIX IT!!
Attn: Arlo rep that I see posting on here.
Is anyone actually looking to fix the Google Home/Assistant linking issue or are you hoping people will just walk away and give up on this feature that used to work perfectly before you update your app and broke the process of linking to Google Home and Chromecasts?
Tried it tonight. Exactly the same issue. Very disappointed. 😞
Having the above mentioned issues. I hate to sell this system and move on but it's been months and no reply. I get the feeling this is not important to the Arlo team.
I have a problem When i tries to link my acoount to my google home app.
what i do:
go to ADD NEW DEVICE and then ALREADY CONFIGURED DEVICES and then ARLO. Then my problem is first time i logged in perfect with my account(my account is a guest account with granted Access) then it says ARLO LINKED, but a few seconds after it Says COULDN’T CONNECT, TRY AGAIN, then i tried again and it didn’t send me to that login page, it was just saying ARLO LINKED and a few seconds after COULDN’T CONNECT, TRY AGAIN..
i dont get that login page. I dont know how many times i’ve tried. It works great with all the other account but NOT with arlo.
is it because it remembers the login information, because that is a very bad methot to use.
PLEASE HELP ME
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
