  • 13 Replies
  • 2614 Views
AngeliquevC
Non of my connected Ultra camera’s are working anymore or not producing anything. I tried to restart my smarthub (VMB5000r6), but it looks like it doesn’t restart at all since nothing changes. I checked for the latest firmware which is the case. I also uninstall and reinstalled the iOS app, no result. I am remote so not at home, so what else’s can I do or can Arlo remotely reset it via a token after I provide then with my serial nr.
hoping to receive a reply
13 REPLIES 13
ShayneS
HI @AngeliquevC
Are you having an issue with Your devices being displayed in HomeKit because I see you have your base station and cameras currently online.
AngeliquevC
I don’t see any camera activity in HomeKit (message for each camera shown is “no response”) while via the Arlo app it seems to me that I have a stuck image of many days ago. When I clicked on a camera, nothing happens and no live view appears.
ShayneS
@AngeliquevC
I reset your HomeKit token, can you remove your hub from the homekit app and re-add it
AngeliquevC
Since I am not at home, I can remove the hub from the app but I can’t install it unless I am near the HomePod hub.
but are you sure that there is not a problem with the Arlo hub?
ShayneS
I see your base station reporting online, If the issue is strictly within the HomeKit app e.g you can't see the cameras or they're appearing offline, you can try removing your base station within the Home app and re-add it in the Arlo app. If you're able to live stream through the Arlo app, your devices etc, there should be an issue with the base itself.
Here's an article with more information on adding it to HomeKit: https://kb.arlo.com/000063184/How-do-I-connect-my-Arlo-device-to-Apple-Home-Arlo-Secure-4-0
If I'm not understanding the symptom correctly, please try to clarify exactly what is occurring so I can better assist.
AngeliquevC
Ok, let’s forget the Apple HomeKit for now and let me concentrate only on the Arlo app, Arlo camera’s and Arlo hub.
 When I open the Arlo app, go to devices, I see all my camera’s and the hub. Most of the camera’s show an image of 22d back. When I click in the middle of the image, it shows Connecting, but within a couple a seconds it stops and nothing has changed. So the image still shows 22d old.
When this happened in the past, I remotely restarted the Arlo hub. When, in the past I did this, I was asked to confirm, and when this was successfully, the message “restart” disappears. Now, this does not happen and nothing happens in my humble opinion with the camera’s.
Does this makes sense?
To be it looks like that the Arlo hub is in a kind of loop. I did remove/deleted the Arlo app already
and reinstalled it, but without success.
AngeliquevC
Here some screenshots when I click under the Arlo app “devices”, and select or refresh the image. I wrote this before but here how it does look like or actually, there’s after the refresh no change of the camera image. It stays the old xdays back.
ShayneS
@AngeliquevC
For trouble shooting purposes, are you back at the devices location to perform a manual reboot?
AngeliquevC
Hi,
no, I am still abroad. I understand that to perform other steps, I need to be near the Arlo hardware?
ShayneS
For this yes, that is Correct.
AngeliquevC
Ok. Then we need to wait. Can we leave this issue open or will it be closed and when I am back home, I fill a new complaint?
ShayneS
This thread will remain open. I'll be here to further assist once you return.
AngeliquevC
Roger that.
I’ll report when we are back home. Thanks right now for the service so far
