- 2
Could I please get a token reset? Having the same problem connecting to homekit. Thanks!
Greglecky,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
I need a token reset to connect to HomeKit
Hi,
Can you please send me a token reset request for homekit?
Pitbullmax, johh
Erniem23, X3digital
I am having trouble connecting HomeKit to my Arlo device. I have reset and re-added my whole system and have not had any lucky. I am using VMB5000 Arlo Ultra Smart Hub firmware version 1.18.0.3_1197_d554faf with iOS 15.5
Could you please try and do a token reset for my device?
Lisadisa,
Can I have a token reset as well, having the same issue connecting with HomeKit.
Luffy96,
Thank you, I am all set my cameras are now working with Homekit.
Hi there, may I please get a token reset as well? Thank you!
Segb, GhastlyDragon
Could you please also send homekit token reset to my base statiuon VMB4000?
Waldekk,
Hello,
I having having issues setting up homekit, stuck on discovering your device. Can you get a token reset?
Thanks,
calengr,
- 2
AppleTV
33 -
Samsung SmartThings
87 -
Security System
