What info is needed from me to get my token reset? Trying to integrate my Arlo cameras with HomeKit.
thanks.
Thank you
Thanks Shane! Everything is working now.
@vicn77 Awesome, thanks for letting me know.
It seemed to have lost connection again, can someone please reset the token again at their convenience. Thanks.
Yup it looks like I have the same issue. All firmwares and apps up to date, stuck in the same "discovering" screen...
Thank you
Thanks @ShayneS ! It was working for a while, but now not working again. Could you please reset my HomeKit token when you get a chance.
I have reset your HomeKit token again, Please reboot your Base Station or Smart Hub and try again.
Thank you
Thanks again @ShayneS, everything is back to normal.
Thanks for the update
AppleTV
33 -
Samsung SmartThings
90 -
Security System
