  • 10 Replies
  • 3526 Views
vicn77
What info is needed from me to get my token reset? Trying to integrate my Arlo cameras with HomeKit.
thanks.
10 REPLIES 10
ShayneS
Thank you
vicn77
Thanks Shane! Everything is working now.
ShayneS
@vicn77 Awesome, thanks for letting me know.
vicn77
It seemed to have lost connection again, can someone please reset the token again at their convenience. Thanks.
scrambleG
Yup it looks like I have the same issue. All firmwares and apps up to date, stuck in the same "discovering" screen...
ShayneS
Hi @vicn77  @scrambleG
Thank you
vicn77
Thanks @ShayneS ! It was working for a while, but now not working again. Could you please reset my HomeKit token when you get a chance.
ShayneS
@vicn77
I have reset your HomeKit token again, Please reboot your Base Station or Smart Hub and try again.
Thank you
vicn77
Thanks again @ShayneS, everything is back to normal.
ShayneS
Thanks for the update
