I feel really dumb. I noticed that I need to set the cameras in “armed” mode for the sensors to work. They work and trigger the sensors alright. I had to create a new mode that doesn’t record when armed as these cameras are indoors and I don’t want to record while I’m at home. Arlo forces you to select an action, if not record, It forces me to send a notification. In less than one hour I got 20 notifications. So I had to turn everything off and not use the motion sensors. In short, I managed to understand how the motion sensors work and I appreciate everybody’s input.
Has anyone else found that after adding Arlo to one Home app on one device that it will not sync to other iOS devices??
Apple really needs to prevent that kind of thing.
Ironically the VMB5000 was not in the drop down list of models on this page.
Ah, okay. Great find. Yep, I never liked Arlo's armed status where you have to pick something. Thanks for the tip
I'm only guessing here, but didn't VMB5000 have some issues at launch? Arlo already started working on HomeKit before that troubled system made it's appearance. Plus the fact, there are probably 10x more Pros & Pro-2 in circulation at this time...
Ouch, sorry to hear that. You would have been better to remove the base station from the Arlo app and start over. It was suggested by another commenter and renaming your base station. It worked for me and found the base station and all my cams appeared in HomeKit. Now trying to get the sensor to behave is the next hurdle...
I saw an email today on this and tried to set it up. It just sits there and spins and returns no devices. Can't even find the code anywhere to try and add through the apple app so can you tell me how this is supposed to be working?
VMB400r3 base station using firmware version 1.14.0.2_2776.
Received the Arlo iPhone app update on Tuesday with alleged Homekit compatability.
Following all instructions exactly to the letter. Granted Homekit data access to Arlo under privacy settings. Checked Arlo settings in Settings menu. Should be good to go.
I try to add Arlo base station to Homekit Home through Arlo app. It can see the base station. It asks what home and room to add it to. But in the final step it returns "Uncertified Accessory. This accessory cannot be used with HomeKit."
I spent quite a long time on Arlo help chat. Help agent was unable to resolve the issue. She suggested that I do a factory reset.
I tried turning the base station off, waiting, then turning it back on again. No change.
I tried restarting the base station from the button in the app. No change.
I tried removing the base station from the app, then adding a new device, then re-adding all the cameras one by one. No change.
I tried doing a factory reset of the base by pressing in the recessed "reset" button and holding it. No change.
I tried doing the Homekit add from an iphone and from an ipad. I thought to do it from a laptop, but the website portal does not have a way to add devices to Homekit.
I tried deleting the Arlo app from my phone and reinstalling it. No change.
Nothing I can think of to do, nothing that customer service tells me to try, and no suggestions that others have provided here on community.arlo.com has helped.
The simple truth is that base station VMB4000r3 is not certified to work with Homekit and cannot be added to Homekit, despite claims by Arlo.
Please correct me if I am wrong. I am open to any new suggestions for getting it to work.
Thanks.
Homekit integration on my system became active this morning when i checked the recent Arlo iOS/iPad app and so I added. Went very smoothly even though i didn't immediatly update the camera or motion sensor names to anything other than the serial number. Now showing on my Mac Home app, iPhone 8plus iOS Home App and iPad Pro 12.4 Home App!!!!!!!
@Cwmmmm wrote:
Arlo homekit official update by anyone at arlo??
My only issue now is the separate motion sensor not working in HomeKit automations.
Thanks.
I can absolutely say this is not the case for every user. I was able to add an Arlo Pro (VMB4000r3) Base station (actually two of them) to Home Kit the first day it was available.
I did get the message that Arlo was an uncertified accessory, but it allowed be to add it anyway.
Yes. i'm a bit OCD on app updates. Like i check every morning 🙂
@Lopezzi wrote:
So removing the base station and re-adding it solved my HomeKit issue. After re-adding it, it found it right away when going to the HomeKit setting. I still had to re-setup all my settings like the geofencing, schedule, and extra modes, but I believe I have it all back how it was now. Thanks all for the help!
Wouldn’t it be nice (and totally logical) if we could export our setup information and import it after a reset or to a new system? What a radical thought.
I was finally able to add my VMB4000r3 base station to my eero network. I have a xfinity cable modem with the wifi turned off. My eero base station plugs into one of the 4 ethernet ports on the cable modem. My VMB4000r3 was originally plugged into one of the other ethernet ports. Homekit did not find the base station until I connected the base station ethernet directly to the eero base station. Odd because the Arlo app has always worked perfectly.
I am left with 2 problems that I cannot resolve.
1. The Arlo cameras only show up in the Home app on my iPhone. I do not see them on my iPad, Macbook Pro or Mac Pro.
2. When I try to view a camera remotely with the Home app, it says "The camera is not responding". I can remotely view the cameras with the Arlo app but not the Home app.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
