I have set up the Arlo Base Station VMB4000 1.16.3890 f/w and Pro 2 Cameras but have the message “This accessory has not been certified to work with HomeKit so some features may not be available”.
It seems a token reset will fix this issue so may I be included in that process?
@ShayneS Please reset my token as well. Having the same issues as everyone else and also have already uninstalled and reinstalled the app and restarted my hub.
Thank you
I have reset your token, please reboot your Base Station/Smart Hub and try again
I noticed that the HomeKit cannot connect to my 2 x Arlo cameras and I tried to remove / add it back thru the Arlo IOS app but failed. can you please help to reset the token for me?
hi i need to get a reset to homekit token please; my device cannot bridge to homekit to view
I need another reset please
Hi guys, I am also having the same issue, the iOS app just Says "Discovering your device Please wait"
used to work fine on the HomeKit but no longer connecting.
Do I need a reset token?
Good Afternoon,
Am i able to get a reset token? I am having the same issue. Apple Homekit stuck at "Discovering your device. Please Wait".
Thank you.
AppleTV
32 -
Samsung SmartThings
85 -
Security System
