HI @cyberr8der @AllanSilkeborg
I have reset you token. Pease reboot your base station and test again.
Thank you
Since I do not see the homekit option, can you reset my homekit token too?
Thank you
HomeKit token reset please.
resetted/rebooted 2 times: no change 😞
FYI, I have 2 stations: have you set the token reset to the serial #5GP608... ?
Can you send a reset token to me as well. Thanks.
donbonanno
bkowalk
(multiple) reset did not change anything. is there anything I missed?
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Dear Arlo support,
I need a token reset please for my Arlo base.
Thanks in advance for your help.
Best regards.
Patrick Ceretti
AppleTV
33 -
Samsung SmartThings
87 -
Security System
