HomeKit token reset
I need a token refresh for HomeKit
When I try to set up. It’s stuck on finding devices
I have reset your HomeKit token, pleas reboot your base station and try again.
Thank you
Hi ShayneS
It is still stuck on the finding your device screen when I try to set up. Any suggestions on other troubleshooting steps?
You can try and remove & re-install the Arlo mobile app while your base station is being rebooted by removing and reinserting the power cable.
Thanks, it's resolved now
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
