Hello,
I'm trying to enable HomeKit and have no code underthe base. According to all the other messages here, I need a token reset. Can somebody help with that please?
Former NETGEAR Employee.
Disclaimer: Views and opinions expressed here are my own.
Can I have my token reset as well?
Is it possible to have the token reset for my router as well?
This has already been reset. No need to duplicate post, or it could potentially get reset again after already being set up.
I have no homekit code listed under my base station. Do i need a token reset?
SN: 4RE3827NA16A3
MAC: B03956E98E65
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
If possible, it appears I'm also in need of a HomeKit token reset for my Ultra SmartHub VMB5000 (SN: A9W3367KD0151). Thanks.
Tomasso,
Hi
how can I get a token reset?
Ypassi,
Hi,
i also need a token reset please.
4RD1757UA0C9B
Thank you 👍🏻
I am having the same problem. Can I have a token reset as well?
4R05827PA8DC9
I also need a toke reset Thanks!
Base Station: VMB3010r2
Firmware: 1.21.0.2_1540_8a519C8
@Rcsager and @WalterG I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:How do I connect my Arlo device to Apple HomeKit?
Hello,
Could you please send a token reset request to my base station as I am unable to add my devices to HomeKit
Model: VMB5000r4
Firmware: 1.21.1.0_1431_9611cf3
SN: 5GP60C7RA09F7
Hello,
Model: VMB5000r4
SN: 5GP60C7RA09F7
Mikael
sn: 5TM1987MA0D9B
I need a token reset as well. Thank you!
Hi,
i need again a token reset please.
4RD1757UA0C9B
This is driving me crazy. Can I get a HomeKit token reset?
AppleTV
26 -
Samsung SmartThings
Security System
