Hello,
I'm trying to enable HomeKit and have no code underthe base. According to all the other messages here, I need a token reset. Can somebody help with that please?
Former NETGEAR Employee.
Disclaimer: Views and opinions expressed here are my own.
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Thanks @JamesC
Unfortunately, there's no HomeKit menu under Settings / My Devices: https://imgur.com/a/8kEDQWw
jak0lantash,
You may need to try factory resetting and re-onboarding the base station. After onboarding the base station as if it were new, I can see another token reset and you can test again.
can you even get a base station anymore?
jbro40,
SmartHubs can be purchased individually from arlo.com here: https://www.arlo.com/en-us/accessories
It's unfortunate I will not be able to enable HomeKit, but I'm not willing to factory reset my base station at this stage...
Could you please reset mine as well?
Netgear arlo pro base station
model VMB4000
s/n 4R036C70A6166
mac a0046080D853
CCS0418,
Hi can I request a HomeKit token reset for the following base stations please:
I have reset my HomeKit but both stations won’t rediscover! Thank you!
Hello James
can you please reset my basestation as well? This is the 3re time for me, why is there no better solution?
Cheers
I have reset your HomeKit tokens, Please reboot your Base Station or Smart Hub and try again.
Thank you
Hi, can I get the token reset please for HomeKit integration?
Patrick
PatrickN88,
Thanks @JamesC. That has done the trick.
Can you send a token reset to my base station? I cannot add to HomeKit.
bm6067982,
Works perfectly. Thank you.
Sadly our HomeKit integration stopped working about 2 weeks ago again. Can you reset my token so I can setup HomeKit again?
TRAVMO,
Hello, I also need a token reset to add my base station back into Homekit.
Hi support team,
can you please also send a token reset for my vmb4000r3 ? I'm having the same issue
S/N: 4RD1737NA0FB7
thanks!
Hi, i would like a token reset - Thanks in advance!
Any way to do this oneself?
Cheers, Casper
danhon, TheGui, detsroh
Can I get a token reset to my second base station for HomeKit?
Thanks!
AppleTV
Samsung SmartThings
79 -
Security System
