From reading other posts I believe I need token reset on one of my base stations in order to successfully connect to Apple HomeKit. I have 3 base stations and one just will not join after numerous tries.
Thank you
Thank you
That worked, thanks very much.
Hello I need a token reset for my homekit.
I have reset your HomeKit token, Please reboot your Base Station or Smart Hub and try again.Thank you
Still not working!
I do not see any devices under your email address. Is there a different email address you are now using. If so please dm me with that information. You send a dm by clicking on the envelope icon on the top right of the forum page.
Can you send a reset token to my base station please ?
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
How do I connect my Arlo device to Apple HomeKit
I need a token reset so I can reconnect my Arlo to HomeKit at my new home. Thanks.
Hardware VMB4000r3
Serial Number 4R05817EAC8AA
Firmware 1.24.0.1_4436_8938370
How do I connect my Arlo device to Apple HomeKit?
Sandy19,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
I'm also in need of a token reset. Thanks in advance.
tqalexander,
Hi James.
I've power-cycled my base station multiple times (I also used to app to restart it, just for fun) and I'm still unable to connect. I'm stuck at Homekit->Setup-> Discovering your device. Please wait. I've been able to get this working in the past and it usually just discovers the device immediately after a token reset, so I'm not sure what's going on here.
tqalexander,
I've sent another token refresh, try the instructions above again to see if you still experience the same behavior.
No change. Still stuck on Discovering.
Hello I also need a token reset for my HomeKit
tqalexander,
If you're still experiencing an issue after receiving the token refresh, then you may need to factory reset and re-onboard your base station and cameras as if they were new. Follow the instructions here: https://kb.arlo.com/1057976/How-can-I-factory-reset-my-Arlo-SmartHub-or-Base-Station
Rehnberg,
I need a token reset too please.
@JamesC
Thank you
It didn’t work. I even deleted the hub from the app. Oh well I give up.
Can you try removing and reinstalling the Arlo app. What is the error messaging received?
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
