  • 11 Replies
  • 962 Views
  • 6 In Conversation
Atlanta1213
From reading other posts I believe I need  token reset on one of my base stations in order to successfully connect to Apple HomeKit. I have 3 base stations and one just will not join after numerous tries.
ShayneS
Thank you
11 REPLIES 11
Atlanta1213
ShayneS
Thank you
Atlanta1213
That worked, thanks very much.
Edgar3tres
Hello I need a token reset for my homekit.
BrookeN
I have reset your HomeKit token, Please reboot your Base Station or Smart Hub and try again.Thank you
Edgar3tres
Still not working!
BrookeN
I do not see any devices under your email address. Is there a different email address you are now using. If so please dm me with that information. You send a dm by clicking on the envelope icon on the top right of the forum page.
Toxiicscorpiio8
Can you send a reset token to my base station please ?
BrookeN
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
How do I connect my Arlo device to Apple HomeKit
https://kb.arlo.com/000063184
wspitz
I need a token reset so I can reconnect my Arlo to HomeKit at my new home. Thanks.
Hardware VMB4000r3
Serial Number 4R05817EAC8AA
Firmware 1.24.0.1_4436_8938370
BrookeN
How do I connect my Arlo device to Apple HomeKit?
