I'm glad it worked, we are working to minimize these occurrences.
I’m trying to setup HomeKit but it seems I need token reset to my device before I can get it to work.
Can you please reset my HomeKit token again? I rebooted my device twice, turned it off but still not detecting my device. Thank you
Can i get my homekit token reset as well. Been searching all over on how to fix this issue.
Thank you
I am unable to connect my Arlo base station to Homekit via the app. Looking on the boards other people have requested Homekit token reset to resolve this problem. Please can you issue me with a token reset.
I have reset your base station token, please reboot your device and try again.
Thank you
Please also send me a token to fix this issue.
Please send me reset token for homekit integration.
Hi @Pryimak ,
I have reset your Homekit token. Please reboot your Base Station and try again.
Thank you,
Mark V
L3 Tech
After updating my phone.
I’m having the same issue. Can you please send me the token? Thanks for your help.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
