- English
- Arlo Forum Discussions
- Partner Integrations
- Re: VMB4000r3 homekit fails with uncertified acces...
@ShayneS Can you send me a token as well. I am having the same issue with adding Arlo Base station to Homekit
@ShayneS Hi Shayne! Can you send me please a token as well? My hub is VMB5000 NA I guess am having the same issue with Apple Homekit.
Thank you!
Thank you! Everything working now!
Hi Saynes,
could you please help to reset the token of my device?
@ShayneS I've got a VMB5000r6 and have been unsuccessful in adding it to homekit via any method (either via the Arlo app or directly from the Homekit Home app). I've removed and re-added the base station from my account a number of times trying to get it working -- it seems likely I've got this same token issue.
I've had the same issue and I just came across this thread where you guys have been resetting tokens. My VMB4000r3 is having the same issue where it says it's an uncertified accessory. I'd appreciate it if you could do the same for me. Thank you guys for your hard work!
Hello,
My arlo camera cannot be connected in Apple Homekit today, can you please help?
BTW, few weeks ago you helped to reset it and it worked until now. what's the issue?
Hi @ShayneS
Can I get a token reset on my BaseStation please?
How do I stop getting email replies to this post?
Hi @skoljatic
You should be able to navigate to your Username/Account > My Subscriptions & Unsubscribe to this thread.
Please send a reset token for Homekit to my base station as I am having the same issue. I go to Homekit Setup and it just spins on discovering your device.
Thanks!
Thanks working now!
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
