- English
- Arlo Forum Discussions
- Partner Integrations
- Re: VMB4000r3 homekit fails with uncertified acces...
Thanks so much. Problem resolved!
Hi, I'm having the same issue. Can you please send me a token as well?
Apparently I am having the same issue - when I try to discover my hub in the HomeKit tab it stays in discovery mode forever and I don't have a code
Shayne, thank you. Nothing changed - I recycled the power, presses Sync, reset - I can see my cameras but clicking on HomeKit->Setup brings the dialog "Discovering your devices"-> DEVICES FOUND with the rotating wheel. It used to be connected to my HomeKit but then something happened, it disappeared and I cannot reconnect it. I don't have a code.
Yuri
I was hoping that worked for you. Thank you for the detailed information. Please contact the Support Team to further investigate this issue with your device. You will find several options for contacting support in the provided link. Arlo Tech Support
What is interesting, is that after approx. 12 hours the base station showed up in the HomeKit without me doing anything. I tried before several times and then after a break - voila! Don’t know what triggered it. But I also kind of proved another “feature” — before, when my cameras were part of the HomeKit I noticed that the batteries were draining very quickly, literally, 2-3 days. I experimented, moved things around but it didn’t help; After the bridge disappeared from the HomeKit my cameras stayed for a month. In less than 24 hours in the HomeKit I lost 10% of power. Is it coincidental or there is some truth in this observation?
Cant connect to Homekit, dont have a code on back of base, tried to recconect in app settings > my devices > smart hub> Homekit. When selected it is stuck and keeps finding device.
Device VMB4540r2
Firmware 1.16.5.6_864_3913242
I have the same experience, fail to connect to the Apple HomeKit. How can I resolve it?
@JamesC Can you please send me the token as well. I am having the same issue and not able to add to home kit.
Thanks,
Dhananjay
AppleTV
32 -
Samsung SmartThings
85 -
Security System
