- English
- Arlo Forum Discussions
- Partner Integrations
- Re: VMB4000r3 homekit fails with uncertified acces...
Can I also get a token reset?
BR Allan
Same problem.
Can you sent me a token as well?
I have am having the issues while adding the base station to homekit. Can I get a token reset as well.
Hi @green12 @AllanSilkeborg @MarcGijs @neilaaron
I have reset your tokens, please reboot your base station/Smart Hub and try again.
I reset your token again. Can you reboot one more time and try again? If the issue persists, please contact customer support to further investigate the issue here: Arlo Tech Support
Hi @ShayneS , Could you resend my token please? I just received Ultra 2 and get the same error when trying to set up HomeKit.
It works now, thank you!
Can get a reset token as well? Just received a VMB5000 and would like to add it to HomeKit.
Hi @wpgtek @BrianMyers @Nheuberger
Thanks I was able to add the Arlo VMB5000 to HomeKit.
So I was able to add the HUB to HomeKit but it is not showing the connected devices (2 ADV001 doorbells). I have re-added the HUB to HomeKit multiple times - but no success.
Hi Shane, could I please get my token reset.. thank you!
thank you. now it worked.
Thanks in advance
Same issue, can you please reset my token?
@JamesC i am having the same issue can you send the fix to me as well.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
