James- sorry to bother you but I am also having same trouble. I have tried removing/adding my base station many times. much appreciated for any help.
Brian
Spirog, Bigredguy
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Colticus,
What information do you need from me so that I can get the fix pushed out, too?
Worked. Thank you.
StargazerOne,
I've sent a token reset request to your VMB4000 base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
May I please get a token as well? I would really like to get HomeKit setup. Thank so much for any help you can provide.
JimDT, z01
Hi, I'm also getting uncertified accessory error when trying to set up homekit.
mariusc23,
I’m also unable to connect. Can I get the token sent as well? Thanks!
JamesC,
Same issue with uncertified accessory here. Sent a token reset request to my VMB4000r3 base station also please.
Thanks!
Andrea85, MAMArco, hgphilippi58, sandizzel
Solved!, thanks.
I’ve had the same issue from day one. Can you help pls?
Same here - token please?
Thank you!
Dam700, Jim1217, Sn1p4h
