- English
- Arlo Forum Discussions
- Partner Integrations
- Re: VMB4000r3 homekit fails with uncertified acces...
The fix for this issue has started rolling out. Please update your Arlo mobile app manually from the iOS store to version 3.5.1 and if you're still experiencing the issue, reach out to me in a private message with your e-mail address and I can send your system a HomeKit token reset.
Thank you
Homekit setup with my VMB4000r3 fails with "uncertified accessory"
I've tried multiple times to log a support call. I either get the error "something went wrong" when attempting to send an email online, or logging a call online, or I get 'live chat unavailable'. This is frustrating at best on multiple levels so this is my last option.
I have tried:
-- multiple times
-- rebooting the base station
-- removed and rediscovered base station & cameras
Each time the homekit setup fails with the same error.
Any ideas? It seems there are others with the same issue.
This is frustrating at best!
Glen.
glenp42,
I will reach out to you in a private message to gather more information.
Thanks James. That appears to have solved the issue!
Thank you again
Glen
Please help
Sure thing. You'll need Arlo support to pick this up and send your base station an updated token then reboot the base station you will be good to go and set up homekit successfully.
Glen.
mward1308, Kabbachi
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
That worked! Thanks, JamesC and Glen!
Byron87,
I've sent the token reset. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again.
I too am having same problem, James can I get the token. Thanks
Melinda54,
It appears you have a VMB3000 base station. VMB3000 does not support HomeKit integration. For more information on supported Arlo devices, take a look here: How do I connect my Arlo camera to Apple HomeKit?
Jason M
Shmorgs,
ClaytonD,
I've had the same issue for many months as well.
I’m having same problem. Token please.
I too have the same problem. Could I request a token reset as well? Thanks
I’m having the same issue. Can you please send me the token? Thanks for your help.
George
AppleTV
33 -
Samsung SmartThings
87 -
Security System
