- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Arlo App and HomeKit creating multiple temp-ho...
Getting an error and can’t find answer
And you are doing what when this happens?
Just another user
I am going into the settings of the app. It’s as it is trying to add a temp home to HomeKit
Hi ramosfranciscoj,
Just to make sure, when you tap on "Settings" on the Arlo app, does that message pop up? Or how did you get that pop-up message?
Have you tried rebooting your iPhone or reinstalling the Arlo app to see if that helps?
I am on iOS13, maybe that is the cause, not sure.
I’ve removed my arlo cameras from homekit and now all the notifications are suppressed, anyone know how to resolve this?
Hey t3hWheez and Sam101,
The issue you're experiencing may be specific to the iOS 13 public beta. We suggest to wait for the actual production release of iOS 13 to see if that fixes it.
Since updating the app and setting up HomeKit. All my cameras are now linked to HomeKit. Everytime I open settings within the updated app there is a temp home created by the arlo app even though I click on delete at the prompt that asks about creating it. Anyone else having a tempHome issue.
I'm not familiar with the Homekit part, but starting today I am being asked to delete some temp-home-xxxx-xxxx-xxxx thing.
Hey colingwalker, Fallof89, jhoney,
What iOS version are you running and what iOS device are you using? Have you tried rebooting your iOS device to see if that helps?
I would suggest to contact the Support Team to further investigate this issue. You'll find several ways to contact support in the provided link.
I have recieved this error message in the Arlo app. What does this mean?
Ig
I'm getting the message on my ARLO App constantly - Delete or No Delete cant stop them from coming. The system is working, but these are annoying.
@Mjgraci89 wrote:
Ig
What does the message say?
You embedded image will not show up until a moderator approves it.
"Attached" files arrive instantly.
Just another user
Are you sure you want to delete your “tempHome-B1FD434...” home? This will remove all accessories from this hoe and cannot be undone. Choice’s are “Don’t Allow” or “Delete”. The tempHome numbers are different but the message is repeated.
@michaelkenward wrote:
@Mjgraci89 wrote:
Ig
The development team is investigating this issue with about pop-up that shows up on the Arlo app regarding deleting your "tempHome." We'll be sure to update the community when we hear any new information. We appreciate your patience and understanding.
I have also just started getting these temp Homes created after upgrading to the latest version of iOS 13, not the beta, the actual release. Cant delete them from the Alro App or the Home App on iOS. Very frustrating, I wont be opening the alro app again until a new version of the app gets released.
Remove the camera from Settings, My Devices and re-sync it.
AppleTV
21 -
Samsung SmartThings
60 -
Security System
