  • 48 Replies
  • 32523 Views
  • 9 In Conversation
Kidibul
Hello,
There is a error message when I want to view my Arlo cameras (VMC3030) on my Google home hub 2 (see picture)
All cameras are working fine in the google app.
Does it have anything to do with End of Life support for this model?
Anyone a solution?
Best answers
  • BrookeN
    I apologize for my delay in response. If you are using the VMC3030 it is not supported by the Google Nest Hub. Is there anyone within the thread that is using something other than the VMC3030 and is seeing this behavior? If so can you please provide the following:
    Google Nest Hub model (1st or 2nd gen)
    • Device model
    • DeviceId of the device
    • (IMPORTANT) The exact command that the user gives and how the user gives the command:
48 REPLIES 48
BrookeN
How about the Arlo app firmware?
Vic_mc
Where do I find that?
FWIW, it's not "app firmware", just the app software version.
It's in the "about" section of the app, so look around for that section.
Vic_mc
maudieinto
When I say "show camera", I get the following message on the Google hub:
Arlo
The camera stream cannot be displayed right now.
When I first logged the problem, when I said "show camera", lines of code would appear on the Google Hub.
Also, if I remember right, I used to be able to view a camera from within the Google Home app on my ios device.  Now, all I get it a black screen.
So, now I'm getting two issues instead of one.
maudieinto
When I say  show camera to the Google Hub, I get the following message on the Google hub:
>Arlo
When I first logged the problem, when I said show camera, lines of code would appear on the Google Hub.
At this point,  I can't view my cameras on the Google Hub or from the Google Home app.
BrookeN
Can I please get the following information:
1. The version of the Google Home Hub
2. The version of the Google Home app(screenshot of the Arlo cameras showing in the Google Home app)
3. If there are other devices working with Google Home Hub?
maudieinto
Looks like I can view the cameras using the IOS Google Home app. But, I just checked and still cannot view the cameras on the hub. The message is cannot stream right now.  Here is the info you requested:
>1. The version of the Google Home Hub<
1st Gen Google Home Hub
>2. The version of the Google Home app(screenshot of the Arlo cameras showing in the Google Home app)<
The Google Home app version is 3.22.101.
Yes. I can turn my TV on and off using the Hub.  I can also turn turn on and off switches from various makers like KASA and IDEVICES.
BrookeN
Thank you for providing that information. We are still currently investigating this.
yetee
I have this same issue as well, but on the Nest Hub Gen 2.
I hope Arlo support responds with a resolution.
maudieinto
it's been a year at least since this issue was reported. Arlo doen't seem very interested.
yetee
Yeah I see that as there are several of these "unresolved" complaints. Too bad, guess it is time to move away from Arlo and look into another system that integrates with stability.
Kidibul
Indeed, don't waste your time here anymore, they won't do anything about it.
BrookeN
I have passed all the information onto our development team. I will update the community as soon as possible.
BrookeN
  • Device model
maudieinto
Did you mean the 4030 instead of the 3030?
The 4030 used to work with the Google Nest.  That's why everyone is complaining.  Arlo did something to break it.
BrookeN
I can have our team investigate this further, however I still need the following information:
  • Device model
  • a) the user says the command using the Google Assistant built into the Google Nest Hub (Hey, Google, show my <cameraName>)
    b) the user says the command using the Google Assistant built into the Google Home App (Hey, Google, show my <cameraName> on <Nest Hub name>)
maudieinto
  • Device model  - Google Nest 1st gen
  • DeviceId of the device - There is no Deviceid spec defined as Deviceid. The serial number is 8B302A0WOKW. The following code is also on the label; GA00516-US. I don't know what it is used for.
  • a) the user says the command using the Google Assistant built into the Google Nest Hub (Hey, Google, show my <cameraName>):  "Hey google show front door camera.
You realize, you've been "investigating" this since at least 8/24//2024 and that you've been asking for the same information.
BrookeN
Are you still seeing this same behavior?
maudieinto
When I say, "Hey Google, Show front door camera," the Google nest still does not display the camera named "front door." Though what displays on the Google Nest has changed.
When I say, "Hey Google, Show front door camera," the ARLO logo briefly appears on the Nest screen, followed by this message:
Arlo
anton1000
Hej, detta är otroligt min kameror fungerade i 1 vecka på min google Neste Hub 2 nu är det inga som fungerar får ett meddelande dina kameror är inaktiva? vad är detta för ett skämt i från Arlo? fixa problemet om ni vill ha era kunder kvar och ta detta på allvar eller vad tycker ni i forumet?
anton1000
Har också skrivit mail ett antal gånger mer får inget svar personligen tycker jag detta är för jävligt, jag driver själv företag sen många år tillbaka och skulle jag behandla mina kunder på samma sätt som Arlo gör skulle jag inte ha en kund kvar idag.
BrookeN
This is still being investigated, I will update the community as soon as possible.
anton1000
Tack så mycket detta är viktigt för mitt företag att dessa fungerar det är konstigt att det fungerade i 3 veckor!
