I successfully setup my 4 Arlo camera for Homekit this morning while at home. They appeared within the Homekit app just fine and I could pull up my live streams. Now that I am not at home, all of the Arlo cameras say "No Response". All of my other non-Arlo Homekit devices are working just fine. Also, if I open the Arlo app, all of the carmeras are online and working properly. However, the Arlo cameras don't seem to want to work within the Homekit app when I am away. Yes, I do have celluar turned on as well as Backround app refresh. Anyone else having this problem?
HomeKit is back up and running this morning.
I have Arlo finally working in Homekit but can someone tell me what the reason is? I show my 2 cameras and 2 motion sensors associated with the cameras and everything is labeled correctly in the Home app, but what now? I've setup motion sensor automation triggers that absolutely do not work. I've tried to setup an automation for when I arrive home to disarm the cameras, but no cameras are available, just the sensors what are 'Always On' therefore unable to select. Only thing useful is that I can see my video cameras in the Home app but I can do that from the Arlo app.
We released a fix on the back end that addressing an issue some users experiencing when attempting to set up HomeKit.
For those of you who attempted to add Homekit over this past weekend, please try again and let us know if you are still experiencing the same issue.
For more information, please refer to this article: How do I connect my Arlo Pro or Pro 2 camera to Apple HomeKit?
Same frustrations...
I can now see the HomeKit Setup under My Devices
I can now see the Basestation and am asked to add it to HomeKit
i can NOT add to HomeKit and receive an "Uncertified Accessory" error
Hardware VMB4000r3
Firmware Version 1.14.1.1_2913_78b189a
You guys are lucky that Arlo hasn't locked your thread... they locked this thread about botched firmeware update, one in which I was partaking...
... can't post replies to it. Isn't their censureship wonderful?
Hi secaz,
Regarding the post you linked (VMB4kr3 firmware update v1.14.1.0_2909_bfcf6... corrupting operational settings), because there was a new firmware update and fixes have been released, we encourage you to start a new thread if you still have issues being discussed in there.
I have set my cameras to turn on all the lights in front of my house when they detect motion and all 3 to start recording.
It has been reliable so far. I'm glad I invested in all Homekit lights at my house.
I am still have the same problem, I go to home kit setup and no devices found
firmware 1.14.1.1
Current firmware1.14.1.1_2913,,,,
Still not working
Basestation not discovered
Need help please.
Arlo needs to give up send an email saying sorry we are idiots and rushed to work with Apple and ultimately failed in a big way. I will give it one more shot after OS13 comes out and see if that corects anything. It also screwed up my automations in Homekit as none work since I actively spent days trying to make junk software and firmware work.
Looking under the hood at the coding all they did was a roll back and patch job to fix some of the code with the Update so the real update is still coming so hold on we will be bricked again really soon!!! Just so everyone’s little HomeKit works and you get the new smoke detector audio and motion enhancement yeh
I 2 can now see the HomeKit Setup under My Devices
I 2 can now see the Basestation and am asked to add it to HomeKit
i can NOT add to HomeKit and receive an "Uncertified Accessory" error as well
Hardware VMB4000r3
Thanks for the update @JessicaP .
Unfortunately no, it hasn't resolved the issue for me.
I'm still getting the Uncertified Accessory error when trying to add the base station to HomeKit for the first time. My basestation is now running Firmware 1.14.1.1_2913..
Also looks like your iOS update to rename the current app to Arlo Legacy has hit the app store presumably before a new app altogether is release. Bad timing I'd think...
Unfortunately no, it hasn't resolved the issue for me either..
Lucky you! None of these steps worked for me. I'll wait until Apple releases the final version of iOS 13. Most of the people who demonstrated that on YouTube or Mac technical sites were using beta versions of that as well as having more recent iPhones than the SE that I have.
I’m wondering just cause Arlo said they would have homekit are held to that statement. I can tell you now that is the only reason why I paid a premium for these camera. It’s not secret there are less expensive cameras in the market
@CALLEN00 wrote:
Still getting the spinning wheel of dead after 4 weeks of homekit finally coming to Arlo. Any idea on a fix?
Have you tried connecting your base station directly in a port at your internet router ? (no bridges on the way).. It worked for me.
I had the spinning wheel until I removed the base station and re added it. You have to resync the cameras and add back any modes created. I have everything working but don't see the point of having Arlo in the Home app except you can see the cameras. No trigger automations work for the cameras or the motion sensors from the cameras.
I’ve tried repeatedly to get HomeKit working with my Arlo Pro2 system (VMB400r3) and even the new Arlo app (not legacy) and current firmware (1.14.1.1_2913_78b189a) are still giving me the uncertified accessory failure messages in the HomeKit setup (after selecting the Arlo bridge).
Has there been any concrete fix for this? I’m hoping that at least the new app will not randomly prevent recording or access to my cameras, as that’s been the main problem I’ve had with this “security” system since Smart subscriptions were introduced.
I’m really losing confidence in the Pro2 system and am concerned that it will miss a key moment of a burglary, or my dog in distress when I’m out!
Please make this system much better.
“As per our L2 Technical support team, the "uncertified accessory" error is a know issue right now which affects some Arlo Pro Base stations.
Our Engineering team is currently working on fix. I apologize that there is no time provide when the update will be released.
I'll have you updated once firmware is released.”
So, they know about it, have no timeline, and there’s currently nothing we can do.
@nxc wrote:
I managed to get this escalated via Twitter. Had a call with a tech who told me T2 would respond. Just received this:
Thanks for sharing. Why can't or won't they acknowlege it here on the community? Makes no sense. Arlo has been failing and if I could afford, I would move on to a different system. Hopefully they will have a release soon, but I bet it will take multiple releases and months.
AppleTV
31 -
Samsung SmartThings
82 -
Security System
